Old 01-01-2015, 07:28 PM   #9
sleepsontoilet
Flex Master
sleepsontoilet Axle snapper extrordinairesleepsontoilet Axle snapper extrordinairesleepsontoilet Axle snapper extrordinairesleepsontoilet Axle snapper extrordinairesleepsontoilet Axle snapper extrordinairesleepsontoilet Axle snapper extrordinaire
Put your gear on a junk set of bearings and add a flapper wheel. Just take breaks to keep the heat down. It's pretty easy to do. Ramon had to redo his after a shop did it, and it was a breeze. You don't "have" to pay for the turn down. The shave kit is barely $100 more than just a diff cover. Ramon posted great tech on how to make the cut in his thread. Then just burn it in. You're welcome to come over and use the 256 whenever.
91 Zuk Buggy
sleepsontoilet is offline   Reply With Quote
