Old 04-09-2015, 09:17 PM   #15
boomtacoma01
Trail guide
boomtacoma01 just gettin started
Decided to add some extra light to the red truck while waiting on some parts and time to swap the tons in. I got it all welded up and in place. It will probably have to be moved back a bit when the light bar is installed to reduce glare. Final placement will be determined by the dimensions of the light bar.
Got my light bar finished and painted. I picked up a 42" radius bar on Amazon that didn't break my wallet. I ran the wiring up from under the hood and up the A-pillar to supply power for the light. I used grommets and some clear poly sealant to seal everything up. I have about a 1/4 inch gap between the bottom of the bar and the roof. I also moved the mount back further to reduce any unwanted glare off of the hood and windshield.
___________
-Chris
85 XtraCab, 22RE, A340/Atlas 2, D60/14B, 40s, Full Hydro, Lonestar Light a plenty
boomtacoma01 is offline   Reply With Quote
