Old 05-19-2015, 06:50 AM   #25
95YJman
Flex Master
95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar95YJman is a splendid one to behold - from afar
You have the neck-down shafts, but on a Toy they may be fine. If you have access to someone with a big sand blaster, it sure makes it easier to clean it up. The knuckles can be done in a cabinet. You have some work ahead of you, but its fun!
I don't know what your suspension plans are, but you can run your knuckles backwards, and put your ram on the back side of the axle, out of the way.
85 Yota truggy, 2.4 Diesel/5-speed/2.28/4.7 twin sticks, D60s front/rear 5.38s, 39.5 IROKs on H1beadlocks
95YJman is offline   Reply With Quote
