| Photo Gallery | Places to Wheel | Home | Forum | Tech Section | IRCChat | FlashChat |
| Axles, Brakes, Steering, Suspension, Tires & Wheels Axles, Brakes, Lockers, Suspension, if it's in or attached to the Axle, it goes here. |
Share | Thread Tools | Display Modes |
#1 |
Trail guide
![]() Join Date: Jan 2010
Someone school me in 10bolts/D44 30 spline conversion...
I got a 72 D44 8 lug with the old style lockouts..I want to convert to the "newer" hub so I can get some 30 spline outer shafts...I think I need to convert my spindles and hubs from an 8 lug 10 bolt or newer D44? right??..Do I need to change my rotors too? I want to keep my current knuckles...Some one get me some guidance!! Thanks in advance...
Here's what I got: ![]() |
| Sponsored Links |
#2 |
Wheelin MadMan
![]() Join Date: Nov 2006
i think you got it backwards. your d44 has 30 spline inner shafts, a ten bolt has 28 or 30 depending on year.
both of those axles use the same 19 spline stub axle shafts so converting from internal to external would essentially serve no purpose except for finding replacement lockouts is alot easier. |
#3 | |
has the bad touch
![]() Join Date: Mar 2005
Extrenal lockouts like in the picture above are very weak.
__________________
Quote:
There is a very fine line between 'hobby' and 'mental illness.' 1. Misfit Buggy - 4.3/W56/Toy-D300 doubler, full hydro steering, 1 tons and 42's, burnin' pane. Gettin there...... 2. The Zombie - Retired 3. The Pig ![]() A dogs philosophy on life: If you cant eat it or hump it, piss on it and walk away....... |
#4 |
Rock Stacker
![]() Join Date: Mar 2009
he's wanting to change to the newer outers so he can upgrade to larger after market 30 spline stubs and 30 spline lockouts.
#5 |
Donating Member
![]() Join Date: May 2007
Warn hub kit.....they dont make anymore bummer
newer chevy d44 stuff, hard to find 30 spline outers + bore out spindles to paper thickness.........Scary + $$$ Ford 5x5.5 internal lock hubs & spindles re-drilled for chevy knuckle......machine shop$$$ wagoner 6x5.5 lug internal lock hub & spindles...............machine shop$$ Aftermarket hubs & spindle sets, like Superior.................Stupid $$$$$$$$ Ford F250 8 Lug d44 tbi front crap..............Machine shop$$$$$ GET A DANA 60............cheap & easy with 35 Splines!! ![]() Last edited by dabshr; 02-05-2010 at 07:58 AM.. |
#6 | |
has the bad touch
Get Rocks, cheaper than a 60.
__________________
#7 | |
Trail guide
Quote:
So back to the original question: I want to convert these 8 lug dana 44 knuckles to the "newer" hubs so I can get some 30 spline RCV shafts and run some 30 spline "slugs"...I just want to know if there is a spicific year -year newer hub off a 10 bolt/dana 44 that I can get to keep the 8 on 6.5 pattern...Do I need to change spindles too( I think I do but im not 100% sure) and will my current rotors have to change or are they all the same? If I had a "newer" than 72 axle laying around I would just compare the 2 side by side..But I don't so I asking you guys... I know the waggy outers would work, but its the wrong wheel bolt pattern... |
#8 |
Donating Member
http://77cj.littlekeylime.com/Dana44_2.htm
Look around here Last edited by dabshr; 02-05-2010 at 03:14 PM.. |
#9 | |
Trail guide
Quote:
#10 |
Donating Member
http://www.coloradok5.com/8lugconversion.shtml
try this too |
#11 |
Donating Member
#12 |
Donating Member
http://cgi.ebay.com/ebaymotors/Chevy...item2eaae0f412
those should bolt on without any other mods...I think? |
#13 | |
Trail guide
Quote:
I think i will have to get different calipers too? I think they changed after 72-73 also and wont work with the "newer" backing plate? Thanks! |
#14 |
Donating Member
#15 |
Trail guide
8 lug to 8 Lug swap
I was thinking about this on the way home this afternoon...I should have titled this thread "8 Lug to 8 Lug conversion"...Could you imagine the answears I would have got then....
...I think I am good to go on this issue now...I am going to search around for some of this 3/4 ton stuff and convert this axle so I can put some beefy shafts in it.. |
#16 | |
Cooler'na13floorelevator
![]() ![]() ![]() Join Date: Dec 2002
You need the spindles for the internal type hubs (6 lug will work also), stub shafts, and the wheel hubs. The 6 and 8 lug axles also use the same locking hubs. Your rotors and backing plates should be the same.
The only change in calipers I'm aware of was the switch from standard to metric threads on the banjo bolts that hold the hose to the caliper. They will both bolt to the same backing plates and use the same pads.
__________________
Zach MUD SUCKS!!! Quote:
75 IH Scout II 79 Chevy K10 80 GMC K25 97 Chevy S10 05 Dodge 3500 Collect the whole set. |
#17 | |
Trail guide
Quote:
It looks like the RCV shafts are a little wider than the GM spindle ( dont quote me for this info)...and the spindle has to be bored out for proper clearence.. I may wait and see if RCV fixes this issue because I dont want thin walled spindles... Im not running Rocks because this jeep is going to be street legal..and a 60 front is overkill for what I am going to be doing at this point...The RCV's are the way to go if I can get them in the axle .. |
#18 | |
The calipers are a different part number because of the metric changeover.
__________________
#19 |
Trail guide
#20 |
Donating Member
the spindles are the same
__________________
i am not really a wheeler, although i play one on the web ![]() Obama lied the economy died |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| d60 thick diff cover 30 spline d60 & 14 bolt spider gears & pin, welded 14b spiders, | HD SCOUTII | For Sale | 3 | 03-08-2009 11:51 PM |
| 30 spline rear 10 bolt axle shafts | 67_SS396 | Wanted | 2 | 02-02-2009 09:30 PM |
| 35 and 30 spline Dana side gears, 14bolt 30 spline side gears and spiders | HD SCOUTII | For Sale | 0 | 01-11-2009 04:36 AM |
| DANA 60 Locker 30 spline | 67K20GMC | Wanted | 3 | 11-27-2008 11:32 PM |
| 30 spline flanges | dott | Wanted | 4 | 12-13-2006 08:18 AM |
