Texas 4x4 Forum - View Single Post - 2 Diff Covers TYD $185 No Options
Old 01-13-2007, 06:29 AM   #1
greatlakeoffroad
Rock Monkey
greatlakeoffroad will become famous soon enoughgreatlakeoffroad will become famous soon enough
Special For Texas 4x4 just reference this web site when ordering. Til Feb 1-07 Well, in the 5 years we have been producing these there have been alot of changes and updates to our line. I thought that we should try and get alot of pictures and all of our options laid out so everyone could see them in one place.
So here are our specs................ all for $100 per cover
- Bolt ring 1/2" thick (we engineer strength where it is needed )
- 1 pc machined fill plug, placed for added oil capacity
- 1/4" thick one piece cnc formed cover (why not thicker? read the warranty)
Only at Glo x-tra cost options......................
- Counterbored mount holes (yes all of them, for a clean quality look)
- Integrated drain (ever cross deep water? Drain it out replace fluid and go)
- 1/2" mid plating severe abuse, makes a nice hydro steer mounting point
- And everything in between
Models available
Dana 70
Dana 60
Dana 44
14 bolt 10.5" R&P
14 bolt 11.5 R&P
Ford Sterling
Ford 8.8
Warranty ( No B.S. Fine Print )
You break it under use we replace it and add you to the hall of fame as it has never been done in the last 5 years. Our design has been engineered for strength. We weld these the proper way utilizing machined fixtures
greatlakeoffroad is offline
