I have been searching for a quick release steering wheel hub. I need it to fit the end of a steering column on an orbital steering valve. Here's what I found. I kinda like the hex shaped Wilwood unit the most, it's the cheapest. But, it might be a hassle to find the pin. It looks like the Pegasus has a ring to release the hub and only about $10 more.
Anybody use these? Opinions?
Moroso Quick Release Steering Wheel Hub $89
http://performance.yoparts.com/moroso_/moroso_quick_release_steering_wheel_hub/80160/i-69833.aspx
JEGS #555-60720 Quick Release 3-Bolt Steering Hub Alum $55
http://www.jegs.com/i/JEGS/555/60720/10002/-1
3400-Size Hex Type Quick-Release Steering Wheel Hub Alum $45
http://www.pegasusautoracing.com/productselection.asp?Product=3400
Wilwood #950-270-2016 Quick Release - 3/4'' Shaft $34
http://www.jegs.com/i/Wilwood/950/270-2016/10002/-1
