I have a rear Dana 35 axle under my 95' YJ that has 4:56 gears, open diff. I'll sell the whole axle for $250 or simply trade you for one that has 4:10's. I just got this jeep and found that it has two different gear ratios in the fron and back when I was changing all the fluids. I just want it back to stock. You can see the axle, gears, etc if you want. I'll post pics tonight.
Just a thought, try and look for a ford 8.8 to replace that 35 instead. There was one on setx.com the other day. Might want to check it out.......
Good luck
Thanks. I have a HP 44 and 9" that will eventually go unfder it but I just want it back to stock so I can use it until then. Guess I should just buy a set of gears and throw them in the 35, just thoight someone could use these...
97greentj on here has a Dana 35 with 4:10s but it's for a Tj, so you would have to wash off the buckets and brackets to weld on perches. Might pm him to see if he wants to rid himself of it......
