Good running 350, less than 100 miles on rebuild. Runs great but pulled so a 6.0 can take its place. It is setup to run TBI but is a carb'd engine. has an Edelbrock performer intake. The wireing is a stand alone system and worked fine. Also comes with fuel pump which is a carter pump. He wants 550 for the engine alone and i will get a price for the whole shabang. Also will part the stand alone system from the engine, 500 obo for the wiring along with the fuel pump and the injector stuff for the tbi.
He has a 1995 T-100 dual diaphram brake booster mated to a chevy 1973 3/4 ton master cylinder to run on toyota. 150obo 12 3/4" long from firewall mount to end of master cly. Diameter of booster is 8.5".
Be cool aluminum radiator for a chevy style inlet/outlet setup. Has small amount of damage from a tree but did not leak and kept the 350 cool. Wants 100 for it. It is a small radiator. Fan is not included. 18 1/4" Tall, 3", 22" wide.
SBC headers for a toyota swap v8. 200 dollars with dual exhaust and some short glass packs.
All Pro 5" lift springs for toyota SAS $200
