Texas 4x4 Forum - View Single Post - gq91sammy
Thread: gq91sammy
Old 09-10-2013, 03:28 PM   #3
gq91sammy
Flex Master
gq91sammy's Avatar
gq91sammy Axle snapper extrordinairegq91sammy Axle snapper extrordinairegq91sammy Axle snapper extrordinairegq91sammy Axle snapper extrordinairegq91sammy Axle snapper extrordinaire
The description of your parts to trade is about as good as the description of our transaction... I took back the lock right because your "set" of tires was now 3 tires.. A set is worth way more than 3 tires, specially when these tires are no longer available. Not to mention I ended up with 2. You wanted to keep the grinder to even out the trade. Which I agreed to.. I then later traded you a "set" of (four) 15x8 8 lug wheels with rock rings for your grinder..only cause you said you could use the wheels...
gq91sammy is offline   Reply With Quote
