some leftover parts i no longer need. all parts are located in waco, texas i can ship at the buyers expense. dont really need much in trade except for maybe some 42" tires or a 40" sticky either for a 17" rim. also some 17" alumiunum 6 lug beadlocks
dual case crossmember/skidplate for a 1983 toyota. not sure what other frames this might fit but it came off a 1983 frame. it worked well protecting the dual cases it had in it. 150$
last i have a homemade onboard air setup. it uses a stock toyota a/c compressor an air tank that bolted in underneath the bed and has front and rear air connections. it works and builds pressure perfectly and is activated off a switch in the engine bay. do not want to split up at this point. not sure what its worth but 150$ open to offers
video
video
