Originally Avalanche Zero G Revamped by Chris Cook in 2010 Located in Cedar Park, Texas 22.5K
Motor- Chevy 350 4 bolt main
Trick flow aluminum heads
tbi from aff. fuel injection
Comp extreme cam
Pro street roller rockers
Shorty Hooker ceramic coated headers
3'' flow master
Rear mounted Griffin aluminum radiator
Edlebrock aluminum intake
420hp
Custom Turbo 350 Transmission 700 R4 Sprag w/ 1st and 2nd gear
TCI manual valve body
stock converter
Atlas 5.0
Front axle narrowed d60 hi- pinion
Yukon 4.56 gears
35 spline longfield cv,s
Rockcrusher drive flanges
Detroit locker
Psc double ended ram
Hughes Pump and reservoir
Dynatrac cover
Aluminum Ator high steer arms
Den bear knuckles
spare axles
1 alloy usa with longfield 300m u-joints
2 chromo shafts with ctms
Rear axle custom built d60
G2 4.56 gears
Auburn spool
Disc brakes
35 spline chromo shafts
Dynatrac cover
Carolina heavy duty long spline drive line Front
Austin Driveline Rear
1350 u-joints
Suspension
Front and rear reverse 4 link
1''1/2 aluminum uppers with hiems
2'' aluminum lowers with hiems
FOA''16" Reservoir Coil overs
FOA springs
Avalanche link mounts & towers
extra set of side pannels
Tires/wheels
39x13x17 BFG Red label 98% 1 trip
17x9 Allied rock-a-thon beadlocks
PRP seats RCI 5 point Belts
B&M Pro stick shifter
Auto meter gauges
Willwood dual master cylinder setup
Willwood pedal assembly
15 gallon aluminum RCI fuel cell
rear cutting brake
Jimmy's Hood
Optima battery
Warn rc winch
Trans cooler
Grant racing wheel with disconnect
108'' wheel base
33-3500lbs
Comp extreme cam
3'' flow master
420hp
stock converter
Atlas 5.0
Yukon 4.56 gears
Detroit locker
Dynatrac cover
Den bear knuckles
spare axles
G2 4.56 gears
Auburn spool
Disc brakes
Dynatrac cover
1350 u-joints
Suspension
FOA springs
Tires/wheels
Auto meter gauges
rear cutting brake
Jimmy's Hood
Optima battery
Warn rc winch
Trans cooler
108'' wheel base
33-3500lbs
