Diode Dynamics is excited to introduce our SS3 Fog Light Kit for the 2006-2012 Toyota RAV4!
SS3 Max LED Fog Light Kit - 3000K Selective Yellow
Instagram User: @LightWerkz
Our SS3 LED Fog Light Kits are now available for the 2006-2012 Toyota RAV4! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
- Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
- Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
Click HERE to check out the SS3 Fog Light Kit for the 2006-2012 Toyota RAV4!
TrustSpot Review - Installation Image
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2006-2012 Toyota RAV4 includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
- Two (2) 3” Angled SS3 LED Pods
- Two (2) H11 DT Adapters
- Mounting brackets and hardware
