1 - 11 of 11 Posts
Diode Dynamics is excited to introduce our SS3 Fog Light Kit for the 2007-2013 Toyota Tundra!
Our SS3 LED Fog Light Kits are now available for the 2007-2013 Toyota Tundra! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2007-2013 Toyota Tundra includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
  • Two (2) SS3 3” Standard LED Pods
  • Two (2) 9006 DT Adapters
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Did you know?
Our team here at Diode Dynamics is an energetic group of over 80 people, who work hard to make quality lighting, with the best service possible in St.Louis, Missouri.
We take pride in our quality products, our customer-focused service, and our work in going "against the grain" to manufacture products here in the USA!
1 - 11 of 11 Posts
