1 - 10 of 10 Posts
Diode Dynamics is excited to introduce our new SS3 Fog Light Kit for the 2013-2015 Subaru Crosstrek!
Our SS3 LED Fog Light Kits are now available for the 2013-2015 Subaru Crosstrek! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2013-2015-subaru-xv-crosstrek.html
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2013-2015 Subaru Crosstrek includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
  • Two (2) SS3 3” Round LED Pods
1 - 10 of 10 Posts
