Diode Dynamics is excited to introduce our new SS3 Fog Light Kit for the 2019-2021 Ram 1500 (non-LED)!
Our SS3 LED Fog Light Kits are now available for the 2019-2021 Ram 1500 (non-LED)! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
- Our SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
- Our SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2019-2021 Ram 1500 (non-LED) includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
- Two (2) SS3 3” LED Pods
- Two (2) H11 DT Adapters
- Mounting hardware
- Mounting guide
