Diode Dynamics is excited to introduce our new Stage Series LED Ditch Light Kit for the 2010-2021 Toyota 4Runner!
Watch Overview Video for Ditch Light Bracket Kit for 2010+ 5th Gen Toyota 4Runner!​
The Stage Series LED Ditch Light Kit for the 2010-2021 Toyota 4Runner allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
Click HERE to check out the Stage Series LED Ditch Light Kit for 2010-2021 Toyota 4Runner!
2014 Toyota 4Runner with SS3 Pro LED Ditch Light Kit Installed
Functional output. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
For states that require them, we also offer snap-on covers for your SS3 and SSC2 Pods. These covers are available in a variety of colors and keep your Stage Series Pod clean and protected from dirt, dust, or whatever else the road throws your way!
See how to install our Ditch Light Bracket Kit for 2010+ 5th Gen Toyota 4Runner below!
