Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2015-2021 GMC Canyon!
The Stage Series LED Ditch Light Kit for the 2015-2021 GMC Canyon allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
See how to install our Stage Series LED Ditch Light Kit for 2015-2021 GMC Canyon below!
