1 - 11 of 11 Posts
Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2015-2021 Subaru WRX/STi!
The Stage Series LED Ditch Light Kit for the 2015-2021 Subaru WRX/STi allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
See how to install our Stage Series LED Ditch Light Kit for 2015-2021 Subaru WRX/STi!
Discussion Starter · #9 ·
Discussion Starter · #10 ·
Our SS3 Ditch Light Kit listings just received an UPGRADE.
Starting on 2/1/2022, all SS3 Ditch Light Kit orders will include a brilliant amber backlight feature!
This integrated backlight gives you an additional accent light, along with the main beam. The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
1 - 11 of 11 Posts
