Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2016-2021 Toyota Tacoma!
The Stage Series LED Ditch Light Kit for the 2016-2021 Toyota Tacoma allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
Click HERE to check out the Stage Series LED Ditch Light Kit for 2016-2021 Toyota Tacoma!
SSC2 Pro LED Pod - Combo Beam Pattern
See how to install our Stage Series LED Ditch Light Kit for 2016-2021 Toyota Tacoma below!
Customizable: If you’re looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on covers are a great option. Like our scratch-resistant SS3 lenses themselves, the SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
