Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2017-2020 Ford Raptor!
The Stage Series LED Ditch Light Kit for the 2017-2020 Ford Raptor allows you to easily mount two SS3 or SSC2 Pods above the hood. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
  • Combo combines both the Driving and Flood optics. The SS3 shines light downrange in a focused, rectangular 65x25 degree pattern, while the SSC2 shines light downrange in a 40x20 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.​
Verified Customer TrustSpot Review
See how to install our Stage Series LED Ditch Light Kit for 2017-2020 Ford Raptor!
Verified Customer Trustspot Review
