Me and cody messed with the truck some this evening. Found some numbers on the block and it appears that it's a 74 Canadian 350 with 882 heads. We took it around the block a few times and got the carb cleaned out. It runs pretty good now, but still not much power.
I poured about 4 qts of fluid in the tranny before it was full. I dont know how it was even working before. Back brakes arent working and I discovered a leak in one of the hard lines. The fan clutch is locked up and the belt definitely needs to be replaced.
