1 - 3 of 3 Posts
Need Help How In The Hell Do You Take Out The Locking Nut Off
From A 205 Transfer Case Going To The Front Axle?
Its On A 80 Blazer. Need To Replace The Seal Its Leaking & Bad.
Its Leaking A Qt. In A Week.
With a socket, I dont remember the size. I just hold the flange with my hand and use an impact to take it off. You can also lock it into 4wd to keep it from turning.
Yep....use the good ol impact to get the nut off...or u could lock it in 4 wheel drive to keep the internals from spinning while u try to turn the nut off.
1 - 3 of 3 Posts
