· Registered
I am going to install a 4" suspension lift on my Blazer and put some BFG 35" A/T tires underneath.
Question - with the lift I'm getting new shocks, extended steering arm, and extended brake lines.
Will I need ANYTHING else? It is a 1984 K5 Blazer.
· Premium Member
Just make sure you have enough travel in your driveshafts, you should be ok but it doesnt hurt to make sure. You may also want to consider some extended front shackles, but they arent necessary.
Also, I'm not sure about with the BFGs, but you may need to do some trimming on the fenders if you plan to do much offroading.
· Registered
going with 4" you'll be fine with your driveshafts and brake lines. You don't have to worry about anything except maybe shocks if you want them. If you need help let me know..........I'm in League City if you need anything.
