Located in Jersey Village (NW Houston)
some pictures:
https://picasaweb.google.com/scott.n.lynda/ForSaleStuff?feat=directlink
Prices are negotiable - just ask
Toyota Parts:
SOLD – late model (86~95) Toyota All-Pro Chrmo shafts
$30 for all, $10ea - (3) Toyota OEM mini-truck rear axle shafts– wide (late model, 86~95)
SOLD! $1000 – Complete Toyota FJ-80 front axle with blah...
$50 - (2) FJ-80 OEM front longside inner axle shafts
$20 - FJ-80 OEM front shortside inner axle shaft
SOLD - pair of Toyota Aisin 30 spline drive flanges (from FJ-80 axle, works on mini-truck axles too) GREAT FOR TRAIL RIGS - or to carry as a spare hub.
$100 - (4) Asin hubs, two with IFS slugs, others empty. Need rebuild. (3) Aisin hub lock dials, one w/o gear
$30 - bearing hub mounted on spindle with bearings (used as spares to hold spare tire in bed)
SOLD $100 - PSC power steering pump for 22RE, scribed 1500 psi on back
$30 - (2) 22RE AC Compressors
$20 - Toyota 8” V6 4:10 reverse cut (high pinion) gears on welded carrier
$50 - 8” 4.56 Richmond 4cyl gears
$30 – Toyota driveshaft (used as spare)
$10 – radiator from ’91 truck with 22RE, small crack at outlet that can be welded. Going to scrap metal if no buyer.
$10 - tilt steering column from ~95 truck. Lock removed
Other stuff:
SOLD $50 – (2) Alcan leaf springs from Toyota front, 6 leafs, centerpin moved ~1" forward ~4.5" lift from SAS conversion. 41.75 eye/eye, 21.75/20 to centerpin
pending - (1) Warn roller fairlead, never used, still in bag
Free - Set of Ford 9” shafts, 28 spline, I think small brg
$10 - D60 open carrier
$20 - (2) Dodge chrome dually wheel insets ($90ea online)
$25 OBO - Chevy 5.3 manifolds (2000 vintage)
$25 OBO - Chevy 6.0 exhaust manifolds (2002 vintage)
Free - Dropped pitman arm – Dodge? YJ?
pending - 4” lift blocks, from 1999 Dodge 2500 4x4
PM here or text to 713-829-2972
Scott
some pictures:
Toyota Parts:
Other stuff:
Scott
