Ok here is the deal…I have a chance to buy a 87 CJ7. It has the 4.0 6 and a 4 speed tranny. Stock size tires, new white rims and pretty much stock everything else. It has a soft-top, bikini, and hard top. All the lights and gauges are intact and work and the engine runs good. It needs a new water pump and some work done on the clutch linkage. The floorboards have surface rust but no holes at all. Also the paint is bad and there is a little rust on the hood. The guy said he can pull 20MPG all day with it giving him a range of 200miles on his 10 gallon tank. He wants $2000 I may be able to get down lower say 1800 or 1700. Is this a good deal? im going to pull a compression test some time this weekend ill post the results...
