can you machine down a dually dana 60 (front axle) to a single wheel
1 1975k5 · Registered Joined Jan 9, 2005 · 5 Posts Discussion Starter • #1 • Feb 9, 2005 can you machine down a dually dana 60 (front axle) to a single wheel
mudgod · Registered Joined Apr 11, 2004 · 5,743 Posts #2 • Feb 9, 2005 I'm sorry, I don't understand the question. I thought all front axle where single wheel. Add a little more info. please.
1 1975k5 · Registered Joined Jan 9, 2005 · 5 Posts Discussion Starter • #3 • Feb 9, 2005 a dually dana 60 is wider where the wheels bolt up to.
RVREDDOG · OOOsahhh Joined Dec 19, 2002 · 3,905 Posts #4 • Feb 9, 2005 Just leave it as is and run hummer beadlocks.
BOWTIE · Where's 2003? Joined Dec 12, 2002 · 4,507 Posts #5 • Feb 9, 2005 1975k5 said: can you machine down a dually dana 60 (front axle) to a single wheel Click to expand... you can, read this. http://www.pirate4x4.com/tech/billavista/60_front/index.html all the way at the bottom it explains it a bit. also there's an ad for hubs, something you might be interested in.
1 1975k5 · Registered Joined Jan 9, 2005 · 5 Posts Discussion Starter • #6 • Feb 9, 2005 thanks to all for the help, i'm just getting into this project & anymore advice would very helpful!
1 1975k5 · Registered Joined Jan 9, 2005 · 5 Posts Discussion Starter • #7 • Feb 9, 2005 been surfing the net & found a set of wheels but they are 16.5 x 8.25. i want to run 44's. these wheels are not wide enough are they?
4x4Freak · Super Moderator Joined Dec 18, 2002 · 6,117 Posts #8 • Feb 9, 2005 Depends on the width of the tires. I'm running some 35x12.50s on factory 6.5" wheels right now.
fourwheelerjeff · Registered Joined Dec 13, 2002 · 5,224 Posts #9 • Feb 9, 2005 1975k5 said: can you machine down a dually dana 60 (front axle) to a single wheel Click to expand... these guys do it: http://wagonermachine.com/ just call them up and ask how much
