1 - 20 of 22 Posts
Well its that time of year again so I have went thru our parts room and decided Ineed some more room so this stuff needs to go. Its a huge assortment of things mostly new that customers ordered and never picked up/paid for now I'm stuck with it. So any reasonable offers will be considered. It ships on your dime. Everything is new unless stated otherwise
Here goes;
Yukon 3.73 gears for a Ford 7.5 used $60.00
AAM 3.73 gears for a GM Part# 108537OE $ 60.00
SMC 400 in rebuildable condition has the original steam ported heads $350.00
BBC HO454 needs rebuild has the good open chamber heads $ 400
Ford 302 1970's engine needs rebuilt $ 250
SHOCKS
ES9000 2-920508, 2-926543 $20 each
Rough Country 9106 $ 20
RS 5401 $ 20
SKY 7298 Dual stabilizer kit $ 150
2-Monroe Air Shocks MA764 $50 pr
2-EXP 92451 $25 each
1-EXP 92450 $25
2-650385 $25 each
2-658562 $25 each
1-650388 $25
1-87317 RC steering stablizer $50
1-650388 $25
1-9159 $25
1-9106 $25
1-650328 $25
1-81272 $25
1-SKY H7018 $25
1-SKY H70515 $25
1-873756 $25
1-650383 $25
1-RC8518 $25
1-RC 8117 $25
Turbo 350 torque convertor 2250 stall? $150
Edelbrock Performer SBC intake $75 (used)
Edelbrock Torquer II 302 Ford $75 (used)
Performer intake 460 Ford $75 (used)
PA 5530 body lift gap guards $30
PA Bkit3 Chevy front bumper brackets 88-98 $50
BBC Edelbrock valve covers, air cleaner heavy aluminum $75
RC Dodge coil spriings 9286 $75
Centerforce clutch for Jeep 4.0 CFT361890 $150 (slightly used 300 miles, checked the paperwork to verify)
Yukon axle YA F880036 (for a Ranger I think) $100
Chevy door handle RH 88-98 $30
Triple guages $20
Ford Add-A-Leaf RC6111 04-07 Ford F150 and others $35
D44 4.11 gears front and rear from a Jeep Rubicon (used) $200 for both
Super Spring # SSA15 NIB sells for $345 Asking $200
Dana 60 Chevy has most parts needs rebuilt $500
Ford 9 rear complete $150
Chevy 14 bolt $250
Chevy 10 bolt 8 lug outers 3/4 ton $350
Ford 9 truck 78 no center $100
Ford 99-02 Dana 50 Nothing past the outer C's $300
Dodge 95 D60 No axle shafts Everything inside is new $400
Well thats all for now. Got any questions just ask
Can you pm me the specs on this? What its missing and what gears it has?
triple guages???
what kind and size???
Me too on the 60
Nobody needs any shocks? These are brand new in the box.
I'm interested in the 460 intake. Pm sent
Would it be too much to ask to have the applications and brands of each? Might make it easier to sell.
Thanks!
Bump for a response?
Thanks!
I agree, I could use some shocks depending on the application or lenghts.
Im still interesed in the chevy 60. Sent a pm but no response.
Discussion Starter · #15 ·
If I have time this weekend I will do some measuring and post up the lengths. Have been swamped at work hired a new guy to help out and he just walked out in less than two hours on the job, never even said he was leaving! What a jerk! Now I'm way behind...
Sounds good. I suspected something along those lines. Did you recive my pm about the chevy dana 60?
is the centerforce pressure plate only ?
Discussion Starter · #18 ·
The dana 60 is complete outer to outer, I have the calipers and the rotors i think...will check and get back to you.
The shocks are listed by manufacturer, but I will try to list them.
The Centerforce is complete with Pressure Plate, clutch disk and throwout bearing. It has about a 300 miles on it, the customer wanted one that was more aggressive.
Would you also check the gears for me? That would be great.
Discussion Starter · #20 ·
The guages are called Shop Basic I think they are made by Equis the same ones who makes alot of the OEM stuff.
1 - 20 of 22 Posts
