Done!!!
Got my headlights that I won awhile back wired up and mounted to the tube clip. This is the list of stuff to finish.
rear driveshaft fabrication
order and install diff covers from BTF
Rubber holders on brake lines
Rubber hose on brake lines
Rear lower links
Angle iron between front link mounts
Fill diffs with oil
Brace front and rear link mounts together
Weld front spiders
fix link between quick steer and orbital valve
brace tube clip to inner frame
Should be able to finish it up this week and this weekend, depends if I have to work this weekend or not. Got our new machine in yesterday and it is going smoothly right now, which is scary.
Rear lower links
Fill diffs with oil
Weld front spiders
