ok, had the same prob... solution was: alot of tuning, setting the timing at 8-10 deg., and getting the big pack of accelerator pump cams, then switching them until ya get most of it gone.. you fuel bowl must be set right, as that can be a prob with the rear bowl.. also, if you go to the biggest cam and still need more gas, you might want to increase the accelerator pump discharge nozzles.. never go more than 2 sizes at a time.. the carb rocks the freekin mic dude,, its not the carb's fault.. you just have to learn how to tune it.. after you get the accelerator pump set (=no more bogs on acceleration), then move on to setting the main jets.... you must reset the idle mix, and the fuel bowl before you set the main jets.. the instructions for that are in the manual and in the post below... once you get it right you will know it.. it will rev fast and have the response of efi... and ya wont have any hill probs either... i must admit i did not know how to do it before i got mine, but i learned from the best.. a buddy of mine thats been racing cars with holleys for years.. hint: old drag racers can tune a holley with their eyes closed.. get some good plugs too.. and how much power is your crate motor getting to the dirt? is it modified? heads? intake? exhaust? pistons? it always helps to know if your dealing with a 150 horse stock target motor, or a 425 hp crate motor..
