How in the world can I figure out what spline front output an no205 has? I've found one out of a 3/4 ton Ford and a bronco. I'm needing a 32spl
Also what all is interchangeable between a Ford to a Chevy 205?
Ford front output on a 205 should already be a 32 spline. You can take off the yoke and count it though.
take the front yoke off and slide it on the rear. theyre the same front and rear. also its a direct swap from ford to chevy. you can even just pull the whole cluster out the back and swap that into a chevy. easier than dealing with the needle bearings.
So are all Ford 205's 32 spline front output?
Yes all are 32 spline front and rear.
