1 - 4 of 4 Posts
I have small block in my truck and want to ID it. The motor is bolted in and I'm not sure if the casting number is visible. All that I know is that its a V8 and two bolt main. This is not the factory motor. Any casting numbers to look for?
One day closer to finish!
Look on the block, rearward side, either on the passenger or driver's side shelf where the top of the transmission bell housing bolts to the engine block. It should be a GMXXXXXXXXXXXXX number.
If you get that number you can Google it or post it up and I can tell you what it is...
1 - 4 of 4 Posts
