Sorry, I wasn't in town when you posted this. I thought I would take the blazer to his shop and have him make me a longer drive shaft. I told him I needed a lot of travel. The first big rock I tried to climb it came apart. I guess I got to much flex. Also I wanted him to fix the leak on the transfer case. It still leaks!. He replaced the U-joints in the front axle. I had hoped he would shim up the front axle for me, but he wouldn't do it for some reason. Did you see the way I cut it up? It did alright this weekend. I should have all the pics up later for you to view.
Looks like I'm going to swap out the 56" front springs again and put some 52" springs in. The pinion angle really is all wrong with the 56" springs. Put the 52" springs in should fix that and not give up any flex. I need to do something new with the back shocks. I busted both of them this weekend. I might be down for a couple weeks. So, I have a lot to work on right now.
