So, due to the fact that my wiring harness is frayed, spliced, respliced, shorted out, etc I tore it all out to build a new harness with just what I need. My problems revolve around the ignition/alternator wiring. My alternator has the letters E F N B. The B is obviously battery. I cannot figure out where the EFN go into the regulator. On the regulator plug I have a blue, whiteblue, whitered, whiteblack, black, yellow and white. from the research I did, white goes to battery, whiteblack goes to ignition, and yellow goes to alt light. So im assuming that those three wires match up to EFN. I dont want to fry an alternator or regulator by plugging them up until it works. also, the coil has a male yellow wire and a female yellow/green wire. im assuming the yellow goes to power but where does the yellow green go to?
