Can anyone confirm this info that I found on Jegs website???
I need to know if a 3.73 12 bolt carrier will accept 4.10 gears???
Jegs website says it will.
12-Bolt 8.875'' Truck
# 8.875'' Diameter Ring Gear
# 1.438'' Pinion Diameter
# 30 Spline Pinion
# Irregular 12 bolt hole cover
# 3-Series fits 3.40 and numerically lower ratio carrier.
# 4-Series fits 3.73 and numerically higher carrier.
# When installing 5.13 and 5.38 ratios, differential pin P/N 80-0269-1 must be used.
Fits: 64-82 Blazer/C10 & K10 rear/K20 rear (Note: Will not fit 2.56 & 2.73 carrier on 80-83 Truck and Blazer.), 69-81 G10 & G20 Van
Use installation kit P/N 836-83-1018-1 or 836-83-1018-M.
# 30 Spline Pinion
