Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2021 Ford Bronco!
The Stage Series LED Ditch Light Kit for the 2021 Ford Bronco Sport allows you to easily mount two SS3 or SSC2 Pods above the hood. The application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling required! This kit features a low profile design while minimizing glare, and will not interfere with raising or lowering the hood.
SS3 Sport Ditch Light Kit - 6000K Cool White - Combo Optic
See how to install our Stage Series LED Ditch Light Kit for the 2021 Ford Bronco Sport!
Customizable: If you’re looking to change the output color, add a layer of protection, or simply add some extra style to your SS3 LED pods, our snap-on covers are a great option. Like our scratch-resistant SS3 lenses themselves, the SS3 Pod Covers are made with a strong polycarbonate plastic, to protect against whatever the road throws your way.
