Well i had posted my project a while back when i jioned but i guess it was lost when there was website changes. So ill just report where iam and what i started with.
I started off with-
1977 Dodge M880
318 two barell
727
np-203
Dana 60 rear
Dana 44 Front
4.10 gears
Fixed up the old 318
started the paint job
Built some RCC hangers and shackles for a 4 inch lift in the front
36 Hummer tires
Started 440 swap
And that pretty much brings us up to date. well close enough.
I just got a Dana 60(30outers,35spline inners) Front out of a 1 ton dually and a Dana 70 rear ( 35spline) 4.56 gears. the plans are similars to Bruiser. I want to run some hummer rims. i think these axles will be wide enough. The rear axle is only a inch shorter on each side. so its not to big of a difference. also plans are to do a 3/4 ecliptical setup inthe rear. 52 inch springs up front and move the front axle forward 5-6 inches for better approach angle. Ive already got a line on a Np205 that i want to get, to reaplce the np203. the 203 doesn't like to stay in loc.
Thats all for now i iwll try to keep yall up dated with the project. I should be installing the 70 and 60 soon.
I started off with-
1977 Dodge M880
318 two barell
727
np-203
Dana 60 rear
Dana 44 Front
4.10 gears
36 Hummer tires
Started 440 swap
