1 - 9 of 9 Posts
Comfortable
Discussion Starter #1
This idea has been on my mind alot lately popcornn
What Im not sure about, is the rear steer setup. I have two options. 1). I can set up the rear to steer all the time,using the orbital valve to send fluid to the back as well as the front. The problem with this is I could only turn the tires in the rear when the fronts turn.....
2). Set up a electric hydro pump....where i could turn the rear on demand...any direction i want. This option would be better i think, but would require I watch my battery draw....I dont want to be out of juice with my wheels cranked all the way one direction nonon
Has anyone gone this route?? I want to run at least 48"treads....52" or 54" if I can swing it. jamminzz Im tired of lookin 4 a front D60... bsflg I can score 2 front rockwells...to my door... for only a few $$ more than a 'junk' D60...
Ideas???? bigok
It would take a little more parts but you could build it using and electically contolled valve like a Skytrak 8042 does. We have them at work. You can use two wheel steer,flip the switch for round steer, and flip the switch to the third position for crab steer.It is all controled with orbital steer valve. The selector valve just detremins where the fluid goes.
the company next door to mine has one of those skytrak things, I was watching it the other day and it would be cool to get ahold of one and check out the engineering of it.
Mas Tequila
I think the Ripper has a good bit of knowledge on rockwells.
your forgetting one option...run a joystick valve to the rear and use the same pump.....
rear
Any way you go this is going to be so cool. Pics as you do it! Good luck on the project!!!
I coppied a couple pages for you today out of a couple of my books. Hyd. sch.wiring sch. and couple other things that give you a this is how it works type pictures of the valving and ports. I will try to scan and post them for you tomorrow if I can. JJ
1 - 9 of 9 Posts
