1 - 12 of 12 Posts
Diode Dynamics is excited to introduce our Stage Series LED Ditch Light Kit for the 2021 Ford Bronco!
The SS3 Ditch Light Kit for the 2021 Ford Bronco allows you to easily mount two SS3 Pods to the factory Accessory Ready mounting points near the a-pillar location, above the hood. No cutting or drilling is required! This kit will not interfere with the antenna, or raising and lowering the hood.
Focused. Traditional optics like reflectors or simple lenses lose light internally and to glare, so not all of the light shines on target. Instead, the custom-engineered TIR optic in the SS3 collects all of the light from the LED, and directs it only where you need it, drastically reducing glare and improving total efficiency.
Learn more about our Total Internal Reflection (TIR) Optics | YouTube
While other options on the market lose as much as 10% of the light output shining through an outer lens, the custom-molded TIR optic in the SS3 serves as both the optic and main lens for greater efficiency and light output (patent pending). Thanks to this innovative feature, when coupled with high-intensity LED chips, the total intensity of the Stage Series Pod is much greater than other LED pods using basic optics or reflectors with a standard outer lens.
Functional output. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly functional beam pattern.
  • Combo combines both the Driving and Flood optics. The SS3 shines light downrange in a focused, rectangular 65x25 degree pattern. The combo lens features a flood optic on one side and a driving optic on the other.
For states that require them, we also offer snap-on covers for your SS3 Pod. These covers are available in a variety of colors and keep your SS3 Pod clean and protected from dirt, dust, or whatever else the road throws your way!
Diode Dynamics Dealer - Panda Motorworks - 2021 Bronco
White or Yellow. SS3 LED pods are available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting.
SS3 Sport Ditch Light Kit - 3000K Selective Yellow - Combo Optic
Custom Submitted Image - Milton H.
The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your SS3 Pods.
Sport, Pro, or Max. SS3 LED pods are available at three different power levels. All options use high-intensity LED emitters, and TIR optics for unmatched focus and overall output. The Sport model uses high-intensity LEDs and is the best bang for the buck you’ll find. The Pro model steps things up in a big way, with double the total power. Finally, the Max model is designed with cutting-edge automotive emitters, for both high power and extreme intensity. This brand new technology comes at a cost, but if you’re looking for the absolute best in lighting performance, the SS3 Max is the answer.
Simple connections. All SS3 LED pods feature a custom-molded DT type Deutsch-style connector on the back, and come with a 6-inch pigtail with bare leads. For installation, you can wire yourself, use an off-the-shelf Deutsch DT sized wire harness, or select an optional Diode Dynamics wire harness. Our Light Duty Dual Output Harness can be used to power up to two SS3 pods. You can also use our OEM Auxiliary Switch Dual-Output Wiring Harness to control your LED pods using the factory-installed aux switch bank.
Bolt-On Installation: The highly durable powdercoated aluminum construction utilizes the Accessory Ready mounting points for a bolt-on installation - there is no cutting or drilling required!
  • Two (2) SS3 3” LED Pods
  • Two (2) Deutsch-style wire pigtails
  • Two (2) Mounting brackets and hardware
Discussion Starter · #10 ·
Discussion Starter · #11 ·
Our SS3 Ditch Light Kit listings just received an UPGRADE.
Starting on 2/1/2022, all SS3 Ditch Light Kit orders will include a brilliant amber backlight feature!
This integrated backlight gives you an additional accent light, along with the main beam. The backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products.
1 - 12 of 12 Posts
