Diode Dynamics is excited to introduce our SS3 Fog Light Kit for the 2007-2015 Silverado 1500 and 2007-2014 2500/3500 HD!
Our SS3 LED Fog Light Kits are now available for the 2007-2015 Silverado 1500 and 2007-2014 2500/3500 HD! These bolt-on kits allow you to replace your factory fog lamps with a pair of SS3 LED Pods. Featuring higher output intensity than any other 3” LED pod on the market, our SS3 LED pods have been designed for maximum light output, with custom-engineered TIR optics shining in highly functional beam patterns, all in a compact, durable package.
  • SAE Driving optic is designed to supplement your high beams, but it’s great for improving general illumination as well. Rather than a typical "spot" pattern, the Stage Series Driving pattern shines in an 18x8 degree spread, providing just enough width to completely light up the road ahead at high speeds.
  • SAE Fog optic provides an extremely wide field of illumination, with high-intensity light output over an entire 80-degree spread. It serves as a great upgrade for any factory foglamp, and will fully illuminate the area in front of your vehicle. Choose your output color of 6000K cool white or 3000K selective yellow, which is popular for cutting through inclement weather.
Backlight Functionality. The Stage Series 3" LED Pod is now available with a distinctive backlight, in a brilliant amber color. This integrated backlight gives you an additional accent light, along with the main beam. The SS3's backlight fully illuminates the TIR optic, providing a more unique and modern look than the small indicator LEDs found in other products. To power the backlight, use the included harness to tap your desired vehicle function.
Plug-and-Play Installation: These kits feature bolt-on installation, meaning they require no cutting, drilling, or permanent modification! Our SS3 Fog Light Kit for the 2007-2015 Silverado 1500 and 2007-2014 2500/3500 HD includes a custom-engineered bracket and bezel for a clean, factory-style appearance.
  • Two (2) SS3 standard LED pods
  • Two (2) Type CH brackets
  • Two (2) 5202 2-pin DT adapters
  • Two (2) 5202 4-pin DT adapters
  • Two (2) PSX26W 2-pin DT adapters
  • Two (2) PSX26W 4-pin DT adapters
  • Four (4) T-taps
  • Four (4) Zip ties
NOTE: This kit is not compatible with the 2007 Classic model. This kit is a replacement for OEM fog lamps. If your vehicle does not have fog lamps, additional hardware and wiring may be needed for installation.
