If you are looking to add driving lights to your 4Runner, check out the Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner from Diode Dynamics!
The SAE/DOT LED Lightbar Kit for the 2014-2021 Toyota 4Runner from Diode Dynamics allows you to mount a pair of SS6 Stage Series 6" Light Bars in the upper grille opening and provides road-legal output as Driving Lights. These application-specific brackets were CAD-designed to install using factory mounting points. No cutting or drilling is required!
Street Legal Output. This kit isn't just for off-road! It is legal for on-road use as driving lights (Please check your local laws and regulations for aiming, installation, and applicability). With the included plug-and-play wiring harness, you can control the kit through your toggle switch.
Designed For Performance. Using optical simulation modeling, Diode Dynamics Stage Series light bars have been designed for maximum functionality, with compact size, custom-engineered TIR optics, and a useful beam pattern, all in a highly durable package. Our light bars shine light in a highly-functional and useful beam pattern, much more focused than older LEDs on the market.
Functional Patterns. All Stage Series beam pattern options were designed with optical simulation modeling, to shape the output in a highly-functional beam pattern. No matter what your auxiliary lighting needs are, there is a Stage Series optic for you!
  • The Driving pattern was designed to supplement your high beams. Rather than a simple "spot" pattern, the Stage Series Driving pattern has a rectangular 20Wx8H degree pattern that is far more useful for directing light downrange at high speeds.
  • The Wide pattern provides an extremely wide field of view, without wasting any light in the sky above and provides a 100Wx8H degree spread of light. It was designed to supplement your fog lights and is perfect for driving in inclement weather.
White or Amber. All Stage Series Light Bars are available in a cool white or amber. The white is a 6000K color temperature, which is a true cool white output, and matches most factory LED lighting. The amber color output, great for high contrast in poor weather or a distinctive look on the road. We also offer replacement lenses that allow you to change the color or optic of your Stage Series LED Light Bars.
  • Two (2) application-specific SS6 brackets for installation on the 2014-2021 Toyota 4Runner
  • Two (2) SS6 Stage Series lightbars
  • One (1) heavy-duty dual-output wiring harness
  • Mounting hardware and guide
NOTE: Compatible with all 2014-2019 trims, but only compatible with 2020-2021 TRD Pro trim package.
See how to install our Stage Series SAE/DOT LED Lightbar Kit for 2014-2021 Toyota 4Runner!
Click HERE to check out the replacement outer lenses for our Stage Series Light Bars!
