Bruiser said:Looking really good!! What rear bumper is that? Did you make it? If so what material did you use?
I have seen alot of bumpers built like yours. Doesn't look or sound too hard of a project. I really need a reciever on the back of mine, maybe a good inespensive project I need to do asap. Thanks for the info on it.Modify said:Thanks, I made the bumper using 3/16" 2X4 tubing. Shackels and the hitch are welded on both sides thru the bumper and welded into the frame brackets. The bumper is currently tied into the four bolts in the cross member and the bottom bolts on the frame. I am going to reinforce the crossmember bolts to tie the bumper into the frame thru the crossmember for added strength.
Rastus said:Nice work Modify toast what did you use for the hinge?
