I have heard my whole life that once you put synthetic oil in a motor you can't switch back to dino oil. Does anybody know why? You can buy a synthetic bleded oil wouldn't this be the close to the same if you switched back and forth?
Brandon
Amsoil says right on the bottle that it's compatible with mineral oil. Why would you want to switch back anyway?
Agreed, IMO all a myth. I've done it and seen others as well. The only thing I've seen is a leak from cover seals, but IIRC it had something to do with seal swelling/shrinking differences in the two, detergents, molecule size, etc. But that was years ago when they first became big. As advanced as oils are now I doubt it’s still an issue.
The molecules are smaller as well as all uniform size. The synthetic doesn't create the leak problem. It just tends to leak before the mineral oils would. Either way, you would have had a leak.
Call me if you want more info. 210 364 3713 http://www.lubedealer.com/tds/
