the hood uses the factory latch and it works great. havent done the reservoir yet, that is this weeks after work project.OldGoat said:Man, it turned out fine and you did a neat job of routing the full hydro lines. Does the hood latch to the tube with the factory latch or are you doing something different? I think that cooler should be plenty large enough. What did you find for a reservoir hose for the power steering tank?
OldGoat said:Also like the way you routed the hoses over then down near the differential and then to the ram, looks nice and you should never have a flex problem, nice job homey!
