Hatch said:If you're using strap
I think its all mild steel..... welderBruiser said:Why would strap/flat bar make any difference?
I thought id double check my manual after you said this.....yep...pg. 3Hatch said:Once upon a time I had a Warn owner's manual. It had a diagram of how to build a mount.
Check again...not metric; decimal inches (engineers like it that way).mudnmyvayne said:I thought id double check my manual after you said this.....yep...pg. 3![]()
But everything is in metric....![]()
Nope....METRIC: 254mmx114.3mm 11.11mm holeHatch said:Check again...not metric; decimal inches (engineers like it that way).
1 strip of 8 inch wide strap......same as plate cut to 8"..... popcornnHatch said:Compare that to two strips of metal passing under the winch inline with bolt holes and you should get a mental picture of how much LESS strong that would be
Mine was decimal inches.mudnmyvayne said:Nope....METRIC: 254mmx114.3mm 11.11mm hole
6.4mm thick
torque bolts to 81-88 Nm bigok
Words...they have so many meanings.mudnmyvayne said:1 strip of 8 inch wide strap......same as plate cut to 8"..... popcornn
